Wood raw materials into PE and PVC two kinds of wood, according to zoning indoor and outdoor timber timber, according to the appearance of the product requirements of sub-surface treatment and need to make a direct color wood grain product treatment process is divided into: one-step and two-step in which products need to make one-step surface treatment, simply adjust the two-step recipe you can directly make a variety of different colors of wood - step necessary equipment: mixer, crusher, wood extrusion production lines, WPC extrusion line according to the specific equipment required for the different product requirements, but also to adjust the device configuration.
WPC storage and maintenance
To learn how to store wood and wood maintenance problem, we need to understand some of the characteristics of wood: Because wood is around the wood fibers and other natural fibers wrapped in a layer of plastic layer, wood water absorption is very low. It is suitable for the waterfront landscape. Wood and wood general comparison, much more important than the wood, usually in the 1.1 to 1.18, while the proportion of timber is generally 0.4 to 0.7, even with a large proportion of hardwood, the proportion of only about 1.0. Therefore, under the same volume of wood is much heavier. In order to reduce the weight of wood products, foaming can be taken to change the profile cross-sectional shape, structure, design methods.
A: wood storage methods:
It can be bent by heating wood. And the right amount of wood is bent to a certain degree. So the long-term storage, attention should be placed on flat ground, to prevent deformation.
B: WPC Maintenance:
Given the advantages of wood, even in outdoor sun and wind, wood will not rot, crack or fracture, in addition also has UV resistance, so the wood does not require special maintenance. This allows future wood product management becomes very easy.
website:wpcproductsupplier.com
