I have a 2000 ranger with bad water pump is there a way to hold pump to break fan clutch loose with out messing the Pulley up
I did it with a strap wrench, might be able to borrow one from Autozone or OReilly's. In a pinch you could use the belt and twist in a length of pipe to hold tight since while you're in there you are replacing the belt, right? :)
