Hi guys, this is my first time on the forum and my first time to post. :)
I bought a 5.0 302 out of a 1998 4wd Mercury Mountaineer that I got a good deal on. Im putting it in a 2wd 2000 Ranger. Everything I read ahead of time said that it would be a direct (easy) swap. The problem is that the Mountaineer motor mounts don't fit in the ranger and the existing motor mounts in the ranger dont line up with the mounting plates on the motor. I'm having a heck of a time trying to get it figured out. Did I buy the wrong 5.0 motor to put in my ranger? Any help or insight would be appreciated!
Okie Dokie:
Try Summit, for adapters for fitting mount on engine swaps, if not have a welding shop make you some custom mounts, I went the custom way for about $50. Hope this helps. JD
