Hi all,
My check engine light came on a couple of weeks ago. I tested it and it came up with a P1443 code. I was advised that the gas cap should be replaced first but that did not resolve the problem. I was then told on another forum that the problem was probably a canister purge solenoid valve. I replaced that part as well and still, no joy. :confused:
Has anyone else seen this? Any advise would be appreciated.
Thanks,
Joe.
not swearing to this but on my 94 the filler neck disintegrated I replaced it at school and my teacher said had it been obd 2 it would have thrown an evap code see if that the issue easyist way pull the bed and its there remembet to disconect tail light wires and filler neck first.
I ended up replacing the Evaporator Canister and the Solenoid Purge Valve. It has not come back on. Keeping my fingers crossed.
Motorcraft CX741 Fuel Vapor Storage Canister - $75.00
Motorcraft CX1158 Vapor Canister Purge Solenoid - $45.00
$120 - To have the system smoke tested.
$240
