1 - 5 of 5 Posts
I put a good 3.0 ff motor into my 2000 4x2. The truck slams into all forward gears, reverse works fine. Put a new valve body gasket in and didn't change anything. Also installed new torque converter during motor swap. Trucks drives great after getting into drive.
So what would be the cause to this?
Rear-end? Bad mounts?
Has a p1000 code
Has a p1000 code
Can you check the EPC pressure and also see what the trans temp is. Does it bang if you manually shift it?
1 - 5 of 5 Posts
