So, I started hearing/feeling something odd. I crawled up underneath the truck and found the transmission all covered in fluid and still kinda dripping, too. How do I find the leak? I need to clean off all the fluid first, I think, but not sure what's the best way to do that.
92 Ranger
4 cyl
Manual
I don't know much about this stuff, but the fluid does appear to be at the rear of the transmission. A friend has filled the transmission oil twice, but it leaks back out pretty quickly.
My 94 4 cyl manual did this get in the truck. take the cupholders around the stick out pull the boot off your now looking at the tower clean all fluid from the area drive it around the block and check again if fluid is back theres your leak.
