1 - 6 of 6 Posts
Hello everyone i have a new issue with the ranger. The transfercase doesn't want to engage in 4wd. I will put it in 4hi from a dead stop and both the 4hi and 4lo lights flash but nothing happens. I am really confused as to why it does this your input is greatly appreciated.
Discussion Starter #2
I fixed it disconnected the positive wire on the battery now it works like it should. It has done this to me once before i am still trying to figure out why.
Glad you fixed it.
So you disconnected the battery positive from the battery and then reconnected it?
You may have a poor connection on the transfer case shift motor. I would check it to make sure the wires/connectors are clean. This may prevent the issue from occuring again.
I will check the wires when it dries up outside. It snowed up here like crazy!.
in my opinion the transfer case motor will stick if not excercised at least once every month (3k miles) ive never seen any tc motor actually worn out from over use..
1 - 6 of 6 Posts
