1 - 9 of 9 Posts
Hey guys, I've decided I have to make a new trac bar. For those unfamiliar with my truck, it's a 1990 ranger with an SAS from '79 Bronco parts. The Trac Bar I have was fabricated from the original '79 Bronco trac bar. Added a threaded rod to make it adjustable. It haunts me sometimes, so it's got to go. Anyway I picked up a couple of Johnny joints. They are perfect for the upper mount as the '79 used a 9/16 bolt for that. The lower mount is causing me to scratch my head. It uses a 3/4" bolt. So now I need to figure out something to use. It has to use urethane or equivalent as this is a street driven truck. No Heims. Any suggestions???
I owe you a beer:) I had no idea they made replacement centers with a larger bolt hole. Awesome. That's what I'll do then.:) Get a LH Johnny Joint and see if I can't get it with that 3/4 one installed. WOuld make a great adjustable trac bar.
LOL... glad I could help!
Currie seems to have a very great selection of parts for Johnny Joints.
I didn't know much about them till a few weeks ago. Now that I have a couple on my desk, I can see why people like them. Beefy as hell.
I might have to look into them for my steering setup in the near future!
Oh, also, do you have any pictures of your frame side mount for the trac bar?
They all come with 9/16 bolts unless you upgrade to the 3" joint. Then you get a 3/4" bolt as standard. Not sure how much meat is on your spindle, but if there's enough, I would go with the 3" joint. After my trac bar is complete, I will have 2 RH joints left over. I'll probably pick up 2 LH joints to make the tie rod/drag link setup. Who Knows?
1 - 9 of 9 Posts
