Okay, I had a pretty productive day with my upper and lower intake and throttle body after a failed junkyard run. Heres what my day was like...
First off I disconnected everything from my composite upper intake manifold and took it off the engine.
When I had that off I went ahead and soaked the crap out of it in throttle body cleaner. I bought 4 cans for all of this and the upper intake manifold too 2 1/2 cans worth. Heres some comparison of the before and after of the upper intake...
BEFORE
AFTER
And then I worked on cleaning the top end of the lower intake manifold.
BEFORE
AFTER
Then I went on to continue my plans with the throttle body. I wanted to trip off some of the pin in the throttle body to allow more air to flow with less restriction that would create turbulance. Sooo, I worked on it and ended up with this
This is the little piece that came out. May be little but it did make a difference in acceleration when speed is already up.
So, I had to clear codes and drive it a lot after I put everything back on because there was still a bit of cleaner in the lower intake. No big, it just caused a lot of misfiring and took 10 minutes of hard running to burn it all clean. Now with a cleaner intake manifold and the extra room for air to pass in the throttle body it is preforming a little better. Actually more than I thought since I figured I wouldnt feel a thing. Took me 4 hours from the start of taking it apart to firing it back up. Not bad for a days work.
