Discussion Starter #1 (Edited)
has anyone had this problem. i just got this truck 2001 3.0 auto and see the seat belt lamp stays on in the dash even with both belts fastened. i have tried to turn off the passenger airbag and the lamp still remains lit. outside of removing the fuse what might i look for. if i have to remove the fuse does this lamp have its own fuse and if so what is the fuse number? i don't have the manual for it.
Discussion Starter #2
got the seat belt lamp problem fixed. i found the wires under the seat were not really making a good connection. hard to tell when you're in the seat. i took them apart and back together and it must have been good enough because the light went out when i fastened the belt.
