1 - 20 of 30 Posts
Its been a long time since I have been on this site.lol But I figured I would update everyone.
-PlumCrazy
no way!! you actualy did it, awesome job
BAD! 8)
how's she do?
Only had it out once so far. Just some little hill climbs and a few short trails, and so far so good. I hit a hole the sunk me up too my headlights and crawled out in 2wd.lol I hadnt locked in my hubs and it didnt look deep, but when I got into it it dropped off lol.
that my friend is fucking bad ass there is alot you should look up on the site we have been busy while you where out plum
Wow!
I'm officially jealous...
That looks really good. I hope you do a write up.
what are you doing with all your ttb goodies? ;)
Discussion Starter #9
Only things left are the d35 beams complete with knuckles and dual piston calipers, and shafts. I also still have an old 3.73 pig laying in the shed.
Discussion Starter #10
I have since swapped in the 5x5.5 rear shafts so all my wheels match.
My next mod will be a doubler. I just swapped in a new trans and clutch, and would like to see this clutch last. I had to slip my last one so much to get over some mild logs and rocks that it didnt last too long.lol 93.9:1 final crawl ratio should take care of that.lol
its bad ass bro was it harder than you though it would be to swap it out
Discussion Starter #12
It wasnt bad at all. I stripped down the axle a while back and converted it do disc brakes using F150 knuckles. I painted it and put all new bearings and seals in it as well as the wedge bushings. I dropped all the TTB stuff ot and the D44 bolted right into my extend RA brackets from the TTB, but the caster was a bit off and I wanted to push the axle forward a few more inches. It took less than 8 hrs all together to make up new RA brackets, trac bar mount, and steering linkage.
thats plum-awesome! ;D
the front is a d44 with f-150 knuckles and the back i think is still a 8.8
Discussion Starter #17
t120r said:
What axles did you use?
75 Bronco Dana 44 up front with 78 F150 knuckles for disc brakes with over the knuckle steering using 3/4" rod ends and 1.5" diameter .25" wall DOM tubing.
98 Ford Explorer 31 spline 8.8 with disc brakes and L/S with custom Dutchman alloy axle shafts to get 5x5.5 bolt pattern to match the front.
Discussion Starter #18
BADINTEN said:
what about the drive shaft did you have one custom made bro
Stock Ranger front shaft still bolts right up and has plenty of slip yoke engagement. I am still running a stock one piece rear shaft from a 98+ 4x4 supercab Ranger.
But the front shaft will need extended about 6" and the rear will need to be shortened about 6" when I get the doubler in there.
good to know that it works for know the drive shaft is a hard part to do on custom stuff
Ah, you're a smarter man than I. The EB axle is MUCH easier to install than the '78-'78 Bronco axle. If I had my time back, I never would have went with FSB axles. What a PIA to set up.
1 - 20 of 30 Posts
