7-19-09
I just picked up my next victim. Its a 95 Super Cab, 4.0 5 speed 4x4. No rust anywhere. It also has tilt, cruise, pwr windows, mirrors, and locks.
I almost have my entire lift, All I need are some extended brakelines and rear shocks.
I am going to run a 4 inch skykacker TTB brackets and some 4 inch coils (for now), I am in the process of making my cross member and finishing up my ext rad arms. I have Chevy leaves and lowering shackles for the back. I am also planning on throwing a disc brake 31 spline under there. I already put on Warn lock outs. I am currently making a deal on 33" BFG AT's and some black steelies. I can't wait to start, I am still fixing all the little things the guy before me left. I already put new wheel bearings, rotors, pads, brake lines, and calipers in the front. I need to put new cab mounts on and replace the spring hangers (perfect time to move them foward 6 inches
) I am also planning on swapping my bumpers, light bar and brand new black 130w KC's off my old rig.
-plumcrazy
7-29-09
I decided to do a little interior work before I tore into the suspension and bumpers. Heres what I got done so far, I swapped out the nasty, musty, stained carpet for a full rubber floor (found at the JY in like new condition for 5.99). I also cut down the 60/40 seat to buckets and put in a full length center console (I was lucky enough to find an Exploder with a blue interior.). I don't have any good pics of the OHC or lighted visors yet though.
I paid 99 cents for a scrap of black nylon material at Wal mart and played around with my mom's sewing machine,(Its kind of scary how nice it turned out)
Goodbye carpet
My amp fits just right under the center console
I made a filler plate for the back of the console since I don't need A/C controls and the back.lol
I had to notch out the back panel and remove the cargo cover and net to make room for my subs I also decided to make my light installation a little bit cleaner on this truck than my last one. I removed the cover where a pass side air bag would be located in the newer Rangers and installed a fuse box from a 94 that I rewired to fit my needs. I wired it so the first six blade fuses in the box fuse the six 30 amp relays, the six relays will power my fog lights, driving lights, roof lights, reverse/cargo lights, and my air horn. I also ran a power wire to my switch panel that off of one of the mini fuse slots. I ran 4 gauge wire from the battery to my new fuse box. I bought a battery with the dual termals (top post and side post) so that my 2 gauge stereo power and my 4 gauge fuse box power wire had a nice clean place to bolt on to. I will snap a few pics of the fuse box and OHC tomorrow. I am still looking for blue vinyl/leather seats and a radio that will light up the same color as my OHC and cluster.
-plumcrazy
Later 7-29-09
I have crappy pic of my OHC and Visors.
I got my gauge pod painted and mocked up, I am still waitng on my gauges. I ordered an Autometer Z-series volt meter and oil pressure gauge ( I wanted something a little more accurate than the "dummy light" gauges that are on the cluster.) I am still trying to find bulb covers so the gauges will light up the same aqua color as my cluster.
The blue paint matches perfect
I decided to go with a dual terminal battery so it is easy to pull power for my extra fuse box and my amp.
Here is a pic of my fuse box that I rewired and installed it the pass side air bag compartment.
I used to two separate relays that are controlled by one switch for the roof lights because I figured one 30 amp relay wouldn't hold up to four 130w KC's. I also ran a 12 gauge power wire to the rear of the truck in case I need 12 volt power for anything. (like my 40 gal diesel tank with a 12 volt pump). I soldered and heat shrunk all my connections. I labeled the box so that you get a better idea of how it is wired up.
I pulled the bed off and dropped the fuel tank. I plan to start cutting off the old hangers soon. I snapped a few pics of the new brackets. Chevy 2 inch drop shackle on my new Ranger hanger. I am also replacing all the 14mm spring bolts with 9/16 grade 8 bolts.
I sat the new hanger about where it will be relocated to. I will have to modify the cab/bed mount bracket. and fab up a new parking brake cable holder.
-plumcrazy
-plumcrazy
7-29-09
Goodbye carpet
-plumcrazy
Later 7-29-09
-plumcrazy
