G
Guest
·I think I have found an affordable option for a lift kit for the 93-97 Rangers. Rough Country offers a 4" with shocks and pitman arm for right around $450. Has anyone had any experience with these kits?
The 2wd kits use a different bracket to lower the pass side beam so its not an issue (not to mention there is no front diff to hit the bracket lol)white94ranger said:well i have the rough contry 4" lift and it went in pretty easy and i have little expirence with working on suspentions, i wouldnt know anything about the clearence though
That is exactly what happened to mine.Biggest issue with the lift, is that it uses a drop plate to lower the passenger side axel pivot, and at full stuff the plate will hit the pumpkin and poke a hole in it.
