This is the setup that I used for my truck any all cars that I work on as JBCustoms that has a music interface involved. I will add pictures of each component soon and post them onto this thread to help out with descriptions.
Note: All of the lights in this setup is Streetglow LEDs, including the undercar kit. Everything is run through the cig lighter and has enough power for it, even for my crazy amount of lights! Once neon is thrown into the picture a larger power source will most likely need to be used. That is because neons use a lot more power than LEDs! Plus neon gives off less light than LEDs so neon is just a waste if you ask me.
I have run with all my light on at a show along with the music running at high power ithout the truck on for 6 hours and it did not drain the battery a single bit. I am also still running a Motorcraft battery, havent upgraded to a yellow top yet.
Let me know if you have ?'s and I will get pics up soon for it.
