1 - 16 of 16 Posts
Re: canada wide lift laws
I'm gonna move this to the lifted suspension section and make it a sticky! Good info!
Discussion Starter · #6 ·
"As a concerned stakeholder I would appreciate any information on present and proposed laws concerning excessively raised vehicles. I understand that there is a committee reviewing this subject, I would also like to know how to contact members of this committee in order to provide input. Any help is appreciated, Richard"
E-mail I sent to the ccmta website http://www.ccmta.ca/english/email.cfm
Please do your part by asking for info too. Use your own words, It "looks" better.
Thanks,
Michigan lift laws are something like the bumpers have to be I think like 30" from the ground and you have to have flares that extend beyond or same width of the tires.
Edit: Found some info
MICHIGAN VEHICLE CODE (EXCERPT)
Act 300 of 1949
257.710c Bumpers; height limitations; lift blocks; prohibited modifications; construction of section; applicability; definitions.
Sec. 710c.
(1) A person shall not operate a motor vehicle on a public highway or street of this state unless the vehicle is equipped with a bumper or other energy absorption system with an analogous function which bumper or system is securely bolted or permanently attached on both the front and rear of the vehicle. The bumper or energy absorption system shall be maintained in good operational condition, except as provided in subsection (5). Notwithstanding subsection (6), a person shall not drive a vehicle having a raised or lifted body height unless the vehicle is equipped with bumpers that comply with this subsection and subsection (2).
(2) A person shall not operate a motor vehicle of a type defined in subsection (8) that exceeds either of the following limits:
Vehicle Type----------- -Frame Height ----------Bumper Height
Passenger vehicle------- 12 inches --------------22 inches
Other motor vehicle:
Less than 4,501 pounds --GVWR24 inches -----26 inches
4,501 to 7,500 pounds ----GVWR24 inches ----28 inches
7,501 to 10,000 pounds --GVWR26 inches -----30 inches
(3) If the GVWR cannot be determined on a motor vehicle other than a passenger vehicle, the limitations for a motor vehicle having less than 4,501 pounds GVWR shall apply.
(4) Notwithstanding subsection (2), a person shall not operate a motor vehicle having lift blocks between the front axle and springs, or withlift blocks that exceed 4 inches in height between the rear axle and springs in addition to those provided by the original manufacturer. Any body lift block shall be of single piece construction and shall not use more than a 3-inch spacer. Any suspensionlift block shall use an alignment pin between the axle and the spring, and shall be of single piece construction. Spring shackle replacements shall not exceed the original equipment manufacture length by more than 2 inches, and coil spring spacers are prohibited. All steering components shall be geometrically arranged to function as original equipment manufacture. Welded pitman arms, drag links, and tie rods are prohibited. All parts used to modify the original suspension or height of a motor vehicle shall be factory manufactured and shall meet or exceed the original manufacturer's specifications.
(5) A person shall not modify a vehicle to be in violation of this section, alter or add to an original frame resulting in an increase in height of the vehicle, or cause the vehicle body or chassis to come in contact with the ground, expose the fuel tank to damage from collision, or cause the wheels to come in contact with the body. No part of the suspension on a vehicle shall extend below the lowest portion of a wheel rim on the vehicle. A part of the original suspension system shall not be disconnected or modified to defeat the safe operation of the suspension system. This section does not prohibit the installation of heavy duty equipment including bumpers, shock absorbers, and overload springs within the limitations of this section, or the removal of a bumper when necessary to install a snowplow, lift ramp, or similar device while the device is in place and operational.
(6) This section shall not be construed to establish standards stricter than those formulated by the United States department of transportation for bumpers on a passenger motor vehicle sold within the United States.
(7) This section does not apply to a vehicle having a manufacturer's design which intrinsically precludes conformance with this section, a vehicle with a GVWR of 10,001 pounds or more, a vehicle designed to carry 16 or more passengers including the driver, implements of husbandry, or a road tractor, truck or truck tractor owned by a wood harvester or contractor and used exclusively in connection with wood harvesting and logging operations, or a vehicle which has an unaltered bumper or suspension system as supplied by the manufacturer. The operator of a vehicle cited for a violation of this section may assert as an affirmative defense that the vehicle in question, at the time of the violation, met original manufacturer's specifications for equipment which affected its bumper or frame height. The operator shall establish by a preponderance of this evidence the affirmative defense asserted pursuant to this subsection.
(8) As used in this section:
(a) “Bumper height” means the vertical distance between the ground and the highest point of the bottom of the bumper, as measured to a level surface when the vehicle is unladen with the vehicle tires inflated to the manufacturer's recommended pressure. If the bottom of the bumper cannot be determined due to vehicle design, the measurement shall be made from the lowest point on the rearmost portion of the rear horizontal bumper bar, or the vertical distance between the lowest point on the forwardmost portion of the front horizontal bumper bar, as measured to a level surface when the vehicle is unladen with the vehicle tires inflated to the manufacturer's recommended pressure.
(b) “Frame” means the main longitudinal structural members of the chassis of the vehicle as equipped from the factory or, for a vehicle with unitized body construction, the lowest main longitudinal structural members of the body of the vehicle.
(c) “Frame height” means the vertical distance between the ground and the lowest point on the frame, measured when the vehicle is unladen on a level surface at the lowest point on the frame midway between the front axle and the second axle on the vehicle with the vehicle tires inflated to the manufacturer's recommended pressure.
(d) “GVWR” means the original manufacturer's gross vehicle weight rating as defined in section 18b.
(e) “Multipurpose passenger motor vehicle” means a motor vehicle, other than a truck or passenger vehicle, designed to carry 10 passengers or less and constructed either on a truck chassis or with special features for occasional off-road operation.
(f) “Other motor vehicle” means any truck, multipurpose passenger motor vehicle, or other motor vehicle having a GVWR of 10,000 pounds or less, not including a passenger vehicle or motorcycle.
(g) “Passenger vehicle” means a motor vehicle with motive power designed to carry 10 passengers or less, or a van having a GVWR of 5,000 pounds or less, but not including a multipurpose passenger motor vehicle, motorcycle, or truck.
History: Add. 1978, Act 225, Eff. Mar. 30, 1979 ;-- Am. 1987, Act 19, Eff. Jan. 1, 1991 ;-- Am. 1991, Act 129, Eff. Mar. 30, 1992
Ohio's Bumper Height Law
(Lift Law)
Ohio Revised Code Section 4513.021
(A) As used in this section:
(1) "Passenger car means any motor vehicle designed to carry ten passengers or less, except a multipurpose passenger vehicle or motorcycle.
(2) "Multipurpose passenger vehicle" means a motor vehicle designed to carry ten passengers or less, that is constructed either on a truck chassis or with special features for occasional off-road operation.
(3) "Truck" means every motor vehicle, except trailers and semi trailers, designed ad used to carry property and having a gross vehicle weight rating of ten thousand pounds or less.
(B) The director of public safety will adopt rules for conformance.
(C) No person shall operate upon a street or highway any passenger car, multipurpose vehicle, or truck registered in this state that does not conform to the requirements of this section or to any applicable rule adopted pursuant to this section.
(D) No person shall modify any motor vehicle registered in this state in such a manner as to cause the vehicle body or chassis to come in contact with the ground, expose the fuel tank to damage from collision, or cause the wheels to come in contact with the body under normal operation, and no person shall disconnect any part of the original suspension system of the vehicle to defeat the safe operation of that system.
(E) Nothing contained in this section or in the rules adopted pursuant to this section shall be construed to prohibit either of the following:
(1) The installation of heavy equipment including shocks absorbers and overload springs;
(2) The operation of a passenger car, multipurpose passenger vehicle, or truck registered in this state with normal wear to the suspension system if the normal wear does not adversely affect the control of the vehicle
(F) This section does not apply to any specially designed or modified passenger car, multipurpose passenger vehicle, or truck when operated off a street or highway in races and similar events.
Administrative Code 4501-43-04 - Specifications
(A) The horizontal bumper shall be at least 4.5 inches in vertical height, centered on the vehicle's centerline, and extend no less than the width of the respective wheel track distances. Bumpers shall be horizontal load-bearing bumpers attached to the vehicle frame to effectively transfer impact when engaged.
(B) Maximum bumper heights shall be determined by weight category of gross vehicle weight rating (GVWR) measured in terms of the vertical distance between the ground and the bottom of the frame rail or bumper. Maximum bumper heights are as follows:
Vehicle Type Front Rear
Passenger Vehicles 22 inches 22 inches
4,500 lbs. and under GVWR 24 inches 26 inches
4,501 lbs. to 7,500 lbs. GVWR 27 inches 29 inches
7,501 lbs. to 10,000 lbs. GVWR 28 inches 31 inches
(C) If the body and/or truck bed height is altered, the difference in height between the body floor and/or the truck bed floor to the top of the frame ail shall not exceed four inches. (Body Lifts)
(D) For any vehicle with bumpers or attaching components which have been modified or altered from the original manufacturers design in order to conform with the maximum bumper requirements of this rule, the bumper height shall be measured from a level surface to the bottom of the vehicle frame rail at the most forward and rearward points of the frame rail.
(E) The height restriction in this rule applies to the distance from the ground to the bottom of the frame rail under any one or more of the following conditions:
(1) A motor vehicle is not equipped with a front and rear bumper.
(2) The bumper height relative to the frame rails has been altered.
(3) A supplemental bumper has been installed or an addition to the original or replacement has been made.
So, I am only breaking a few rules.
6" over the bumper height law.(Just 6 for now.lol.)
Tires are wider than body.
Sway bars are a thing of the past.
Here is what I could find on California.
What you can do is dependent on the GVWR. If your truck's is 4,500 pounds, the maximum frame height is
27 inches. If the GVWR is 4,501 to 7,500 pounds, it's 30 inches, and for 7,501 - to 10,000-pounders, it's
31 inches. Also keep in mind that the lowest portion of the body floor can't be more than 5 inches above the top of the frame
1 - 16 of 16 Posts
