I have an 89 ranger I have put a new fuel pump, ignition control module, fuel pump relay, ignition switch and, a different computer.. It still will not start, it has spark but the fuel pump will not come on and, I have no power to the injectors. I really need help and, a wiring diagram if any body could help I would greatly appreciate it.
Thank you.
Roman
One of your best investments will be a repair manual. @ ~ C$25.00 it will save you a lot of money and time in the long run. If you don't hear the pump then check the wires for bad connections and ALL GROUNDS. Do you have power at the pump? Does your model have just one in tank high pressure pump or does it have the low pressure in tank pump and a high pressure pump on the frame rail [ would be below your feet on the frame behind a metal bracket ] ? Clogged fuel filter?
89 would have the single high pressure pump in the tank. i also agree with checking all the grounds. some may look ok but a new clean ground will make a huge difference
