1 - 5 of 5 Posts
Sick! Great job man!
The only thing to look out for is your driveshaft. With the 6" lift or higher, it puts a ton of strain on our carrier bearing. Mine wore out in about 3 months with the Skyjacker 8" lift.
I put a 98+ one-piece 4x4 shaft in mine and it works great!
Thanks for the heads up. Mine has a 1 piece shaft already so I guess I lucked out. I was really surprised that I did not have to lengthen it. But it looks to be plenty long.
That looks good. How long did it take you to do? I saw that you have a shop so it may have been a little easier for you. You should also give us some stats on your truck and what type of off roading you like to do.
Cheers,
Ah, well that is lucky! I notice from your picture that your dash is the 93-94 style. Mine is a 97, so they may have been different.
Cheers,
I agree, what type of wheeling are you into?
1 - 5 of 5 Posts
