1 - 20 of 30 Posts
so i bought torsion keys and they adjustable 1-2 in the front. i have a v4 4x4 xlt and i was wondering if i have to lift the rear as well or the front is gonna do it? i wanna lift it without extending..what should i do? or what should i but if i gotta lift the back? i dont have the bigger tires now but planon putting them on..im runnin 255/70.16 right now and wanna go with bf authorities 31's
Do you have a factory 2" lift block on the rear axle? It would be a block shaped piece inbetween the axle tube and the leaf spring.
If so, you should be fine as a 1-2" lift for the front would level the truck out.
If not, you have a couple options:
The easiest would be two purchase and install a 2" lift block.
You could also purchase a set of Chevy drop shackles. The tech article is located here: http://fordranger.net/index.php?page=11
ok..i wanna go the easiest way..im thinkin the blocks will do? i think they are pretty cheap too..
They are the cheapest route and actually come on 4x4 Rangers from factory, so they are definitely safe!
Could you get a pic from the back side of your rear axle (under the truck)? This way I'll be able to tell you if your truck has blocks or not. The picture makes it difficult to tell since it's somewhat on an angle. It looks like it's not higher in the rear, so my guess is you don't have them.
I found this on eBay. Looks to be a factory set (actually comes with three, but you only need two). And they're less than $50 shipped!
http://cgi.ebay.com/ebaymotors/1985-95-96-97-FORD-RANGER-Rear-Lift-Spacer-Blocks-OEM-_W0QQcmdZViewItemQQhashZitem4aa504412fQQitemZ320596099375QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
your only doing a 2-3 inch lift on the front dont mess with the back or it will look how it does now only a lil tall and not much mind you
Well, if he doesn't have anything lifting the rear, the truck will sit higher in the front.
I would really recommend installing the lift keys and seeing how it sits at that point. You may like the look and decide against lifting the back. Then, if you still want it higher in the back, go with the lift blocks.
if he has blocks or not the back will still be higher all trucks are higher in the back so when your towing a load it levels out. the tbar key is a level kit not a lift kit so it will make the truck sit level
well people like the broke spring look lol i usely go a inch higher in the rear. but i usely use load leveling system spring helpers
Discussion Starter #10
ill snap a pic tomm.. i def wouldnt mind sittin up higher anyway..i def dont wanna have to bring it back i case it does sit hight in the front..but why else would they call it a leveling kit right?
ive seen some of the kit lift the front higher for some odd ass reason. the kit a friend got for his 2500 hd lifted the front higher then the back did i gave him a load leveling it help a lot till he took on a load.lol
It looks as though you have a 1" block in the rear (actually didn't know those even existed).
With the leveling kit, you will probably be sitting pretty good. I say get that sucker installed and post up the pics!
Discussion Starter #14
so i can change that though right ? to maybe a 2 or a 2.5 inch block? jus in case i wanted to do all together..im makin the apt on mon for somtime during the week..fx demons is where i wanna be but he did a 3 inch body lift..i got a 2 inch max..well see how it goes..ill put um up
The blocks can definitely be replaced with larger ones.
BADINTEN said:
you said you were going to install this your self and yes you can change the back block out but i wouldnt unless you lift the front more
aww y not what wrong with the raked look lol i usely do my lift in the front first then see howhigh i want to go in the rear but we have a skyjacker shop really close by that carries ne thing i could want on hand.(i only do the front first cus its usely more pricey inless it was my old gmc then nothing was cheep at all
the rake is not my problem but when its lifted it looks better with a rake starting in the front like this Front<---__Back. when its lowered it should be raked from the back forward front<__---back like that just imo
Discussion Starter #20
so how do i lift the rear? and with what? im looking to boost it up bout and inch or 2 already got the front in and it looks good..the front can go higher because its adjustable so i just need the back to go up..what do you suggest?
1 - 20 of 30 Posts
