1 - 8 of 8 Posts
Alright, thought I’d do a helpful write up on interior painting since there’s allot of questions about it. So far, I know that KRYLON FUSION spray paints work and require no sanding, or prep aside from cleaning the dash. I have also heard that Duplicolor works, but I haven’t tested it personally. Alright what you'll need to paint your interior if you DONT WANT TO REMOVE YOUR DASH! 1) LOTS AND LOTS of Newspaper 2) Automotive painters tape, I found that normal painters tape doesn’t stick well to the plastic. 3) 5-6 Cans of spray paint, I used 5 of black and then 3 of blue because I did a 2 tone style. 4) A fan, and well ventilated area 5) TIME!
First up, I did my doors seeing as they can be taken off. Remove the 3 screws from the front driver’s side and passenger side doors, and for the back 2 doors (if you have a XLT) you will need to use a T55 torx socket to take off the seatbelts to get the doors free. Now, tape off the Vinyl part of the door, because I’m not sure how well spray would work on that, if you want to do those, buy fabric and use adhesion promoter, and some sort of fabric. Clean the doors thoroughly and if you want to 2 tone the doors, obviously tape off the area you want a different color. REMEMBER IF YOUR 2 TONING, IT WILL TAKE LONGER BECAUSE YOU HAVE TO WAIT FOR THE BASE TO DRY COMPLETELY TO TAPE IT OFF! Now, spray your first coat on the doors without going to heavy!!To be safe, I waited till each coat dried before I started the next coat, this will pay off in the long run!
Now, while you’re waiting for your doors to dry, or once you want to start your dash, cover your entire floor with newspaper, or tarp, even cover your seats! Spray paint can and will be in the air (duh) and can get on things you don’t want! (Duh) so be sure to mask off everything! Also, news paper off the windshield, tape around the edges of it, and then more news paper! You don’t want to buy a new windshield so take your time! Now, prepare to be frustrated while taping off the dash, there’s more little things you don’t think about then you think, so be ready to take awhile to tape off everything!, wrap the steering wheel in newspaper, and then tape off the spedo cluster, radio cluster etc. Now, you can take out the vents (good idea) and then fill the holes with news paper to keep paint out. I did 4 coats I believe on my dash, 3 in one day, then waited overnight to do the final, be cautious and go over the dash carefully! Take your time, you don’t want to find out you missed something after all the paper is out!
Lastly, put the doors back on once there dry, and leave all the doors open, and turn your fan on high, it will take a few days for your car to air out so be ready. Also! Wait to clean your dash for a weekish! Make sure it’s completely dry! If your dash feels a bit rough after it dries, not to worry, the same thing happened to mine, and once you clean it, it will smooth out I’m guessing it’s just paint spray that got up a bit.
Well that about it! Ive had mine painted for 4 months and love it!! You can check out the results on car domain here: http://www.cardomain.com/ride/3359764 and comment and rate my ride if you want. Thanks guys, hope this article helps!! Ask questions if you need anything!
sweet write up! do you have any pics from when you were doing it? or just afterwards?
I always forget to take pics during the process... LOL
Thanks, just trying to give out some helpful tips. And nah not during, i always forget about it too!
I always intend to take pics and I run into that one problem that occurs in every project and there goes the picture idea.
Great How To guide! Im looking to redo my interior to be all black with better yellow accents soon!
1 - 8 of 8 Posts
