1 - 6 of 6 Posts
for the air vents i pretty sure you need to take them apart and paint them, not sure about the radio bezzle
Okay... the radio bezel has that stupid rubbery stuff on it that you must remove by sanding down or peeling off. After that is done I did the following steps...
#1- Prime all pieces
#2- Sand pieces with meduim grit sandpaper
#3- Prime all pieces again
#4- Sand pieces with fine grit sandpaper
#5- Prime all pieces again
#6- Sand pieces with very very fine sandpaper
#7- Allow primer to fully dry and make sure its nice and clean from sanded particles
#8- Paint pieces with desired color rattle can
#9- Sand pieces with fine grit sandpaper
#10- Paint pieces with color rattle can
#11- Sand pieces with very fine sandpaper
#12- Paint pieces with color rattle can
#13- Sand pieces with very very fine sandpaper
#14- Paint pieces with color rattle can
After all that you can add clearcoat if you want but a lot of rattle can paints have plenty of gloss in them. Especially if you do the paint and sand this many times you will already have a great layer of strong and smooth paint that with look great. For primer use and paintable primer. And for the actual color just anything you want. I personally use Duplicolor but Krylon is good too. Just depends on what is available and what colors are offered. Duplicolor has exact match to my Chrom Yellow so thats why I use that. Hope this helps!
1 - 6 of 6 Posts
