in my 89 BII, i changed out the headlight bulbs for some ebay ones that are crystal white and they were awesome for the first couple times i used them and now when i turn on the headlights, the passenger side bulb is very dim, you cant even tell its on unless you get out and look at it, and that same side signal light dont work, and the signal indicator is on in the dash when the headlights are turned on.
thanks for any help i can get
the signal is on all the time on the dash? if it is, it means you have a burnt out bulb, or even no bulb, but if the bulb is good start tracing wires from that turn signal and youll probaly find a frayed wire or cut wire of some sort. but i would wait for some one more expirienced with electrical because electrical isnt my best subject.
I generally hate wiring but I would start looking at you grounds. That's what is sounds like to me. I just ordered mine so if I run into the same problem, when I figure it out I will let you know.
