L
lostro76
·Guest
The axle on my 94 B4000 will not engage. It has the push button selector and the factory automatic hubs. It does make a click under the cab when I try to engage it. Any ideas?
I'm going to flat tow my '91 race truck. It has the electric t.c. Can I shift it into neutral with the vise grips? Also has auto hubs, can I take man. hubs off another truck to swap in?PlumCrazy said:I toyed with the idea of making up a manual conversion for my electric tcase, but since the shifter shaft is on the back and must rotate perpendicular to the transmission (were as a manual case has the shifter on the front and rotates inline with the trans) it would be very difficult to make something reliable. If you remove the shift motor, then you can use a pair of vise grips to shift it (there is even a shift pattern cast into the t case) I shifted my t case that way for a while.lol I ended up getting a good a deal on a manual case, so I put that in.
-plumcrazy
