Just thought I would get the ball rolling in this section.
Here are a couple pics of my ext. rad are setup
This is my first design for the RA mounts/ trans cross member
You can see that the bushings are almost maxed out with less the 6 inches of droop (thats why I redsigned them)
When I remade the brackets, I gusseted the plate that the bushing goes through, and dropped the mounting point down a little to get a better caster angle and to allow for more articulation of the arm
I had to trim the RA bushing a little to tighten up in the new bracket
I extend the arms 13.5 inches with 2x2 1/4" wall tubing
and beefed up TTB drop bracket
