Does anyone make a kit to replace the electric shift ( 2WD , 4WD Hi , 4WD Lo ) motor on my truck ( '98 Ranger ext. cab 4x4 ) with a manual shift lever ?
Nope. I thought about making something to convert my old case, but I found a manual 1354 case for an awesome price. It would take an awful lot to make something durable and reliable. The biggest challenge is the fact that the shift shaft is on the back of the case.
Just bought a 2001 4.0 4wd. When I start the engine I have no 4x4 light on dash. Moving switch from 2wd to 4lo or 4hi does nothing. No lights, no clicks or other sounds, and no 4wd. I know I have a switch, control module, and actuator motor. I don’t have a fuse diagram (no manual with truck, I...
My #35 (15amp) fuse recently started blowing out.. :(
While driving in heavy rain, my 4 HI and 4 Lo lights began to flash 6 times every 2 minutes. I don't have the manual for this truck.. The truck was manufactured in November 1999. The 1999 fuse diagram that I did find (Internet) doesn't...
Can the transfer case (the male part that goes into into the transfer case motor) be turned by hand to line up with the new TC motor?
Can I use vice grips on a piece of rubber over the shaft end to turn it to match with the motor?
Thanks.
My son and I are planning to take a road trip next weekend. Can you guys give me some tips on what accessories I should bring during our off-road escapade? I own an 07 Ranger.
