i had to remove the transmission due to not shifting and while doing that i noticed the rear of the oil pan gasket hanging out of the pan, maybe why i seen a lot of oil there? anyway the front was worse. so i took the bolts out and lowered the pan and seen the gas is rubber and all beat up. so how har is it to replace that gasket without lifting the engine? this gasket look like a one pc. and i have seen 4 pc sets. i guess that should be easier if they still make them? what is the opinion here? also i will change the rear seal. the truck show 190k engine may be the same shold i try to install a ready sleeve or just instal the seal and be done with it? the front one stillis dry so i will wait on that until i have to deal with it.
the main item is the oil pan gasket? thanks
