Yes you can crank it yourself. I don not have pictures of it, i can try to get them later, but there are bolts at the end of the t-bars under the cab of the truck that you torque. The front of the truck has to be lifted off the ground so the suspension is expanded. When you atualyy torque the bars you have to make sure you torque each bolt the exact number of times or else you will have a lop sided truck in the front.
Thats just the basics until I get picks and refresh myself on the process but im sure someone else will chime in with this.
