1 - 19 of 19 Posts
whats up guys. i'm Rico i live in SLC , UT and i have an 84 BII with 7" of lift, 33's, chopped top with a sealed cab and flip up rear window, round headlights, removeable doors, durasparked, and am just waiting for my warn manual hubs to arrive so i can swap in my dana 35 and 8.8 with 4.88's and aussie lockers. here are some pics:
Welcome to the site!
Very nice BII. That's some killer flex!
That's crazy! Could you get a couple close up pics of your bed rails? Thanks!
Discussion Starter · #5 ·
ask and you shall receive! i used some diamond plate rails from a dodge truck that i shortened to fit. they are just screwed in with some self-tapping screws.
Discussion Starter · #8 ·
i couldn't get it to pass IM in UT so i used my mom's address in WA. i have to get it re-registered now it just expired but i found a guy who will pass it here so i will have utah plates next week.
dudeeeee, sweet Bronco! nice lift and flex pics :eek:
That's got to be one of the most awesome mods done to an old BII. Skies the limit on what you can do to make it into what ever you want it to or what you intend to do with it. Is that a 5.0 or the 2.9 with the edelbrock. Valve covers look like the 2.9 but the pulley setup looked different.
Discussion Starter · #13 ·
i used the stock back hatch to make the back of the cab. i trimmed it a bit the screwed it in place on the top and sides. on the bottom i used a piece of angle iron. then lots of body filler. you can see some more detailed pics here:
http://www.cardomain.com/ride/2374024
Discussion Starter · #16 ·
she's in Olympia. i also have alot of family in and around Puyallup. i also have to go to Longview sometimes for work. i get up to WA at least a couple times a year. where are you located?
Discussion Starter · #17 ·
Dyllan said:
Ive seen your truck on bii.org. What is you wheel backspacing? Im in the progress of the D35, and 8.8 swap now too. What did you use as the back of your cab?
not quite sure about the back spacing. the rims were on it when i bought it. they are 15"by10" if that helps. i can measure how deep they are tomorrow.
1 - 19 of 19 Posts
