well i'm going from 3.73's to 4.88's. never had to change gears before. any tips? do i need any special tools? also putting in lockers for the first time. thanx in advance.
from what i have done the hardest part to me was setting back lash making sure the gears grab just right. the only special tools i used was a slid hammer, pully puller for the drive shaft flang, and a press to put the new bearings on the pinion gear and the carrier. its not to hard but you need to take your time on this you dont want to get dirt in there at all but you know that part already.
sorry i thought i posted this already i just used colored grease to set the gears. put some grease on the ring gear spun the gears a few times to see the contact path. it was a trial an error things but it was just one shim shy of what we wanted. so it was a good all an all i would do it again.
How to read your axle:
The rear axles come with a tag (see photo below) that should be attached to a bolt on the rear cover. If there is no tag, someone has unfortunately removed it, and it will be difficult to determine which axle you have. There is also an axle identification code inside the...
I’m in new of a rear end 8.8 ring gear, 3.27 gear ratio with 10” brakes, is there any other vehicles that have this configuration that can be swapped with?
My four wheel drive doesnt work in my 02 ranger im told its a common problem also i have a b4000 thats doing the same thing .Can i put locking hubs in them for them to work
Hey guys. I'm new here. I have a 1990 ranger xlt 4x4. It has an m5r1 and a 2.9 v6.
It's long bed regular cab, if that would matter. I am milking the 2.9 along, but it has a bad case of sitting sickness, (abut 3 years) from before I got it. From what I have seen 2.9 long blocks are pretty high...
