I need some suggestions for a donor that I can steal the hand controlled e-brake actuator from; between driver and pass. seat. Prefer ford but easiest install is key.
Thanks
Thanks
That's kind of where I was going with this idea in my head. Never done or seen it done. So you would pull the right one (passenger) to turn right?sloue said:the jy are full of escorts and tempo or topaz what ever they were they are dead simple. if you want one for rallying the vw golf brake is simple to mod the ratchet and a return spring and u have a rally brake.used to put two side by side and run a cable from each to its own back wheel cheap steering brakes. i was into dune poppers when i was a kid![]()
Thanks, I'll keep it in mindcvalcore said:i no its a chevy but the 82-92 chevy camero and firebirds had a center e brake also
Wouldn't it make doing more burnouts a little easier if hooked up to the front brakes? Gave it some thought a while back.Red said:whats it going to be used for?
