Yep you take off the original radius arm crossmember all together. You replace the trans cross member as well.white94ranger said:if you have those on your truck can you take off the drop pieces for the rad arms? like for my 4" lift theres drop piece and it looks wierd havin the truck raise but then having this block of metal hanging four inches down
They are going to a member on TRS.red said:who are those shipping out to plum and white ranger take a pic of what ur talking about it would help out alot with a pic easier to explain what ur talking about man![]()
cool manPlumCrazy said:They are going to a member on TRS.red said:who are those shipping out to plum and white ranger take a pic of what ur talking about it would help out alot with a pic easier to explain what ur talking about man![]()
-PlumCrazy
I could deff do that, but I would need some pretty precise measurements.rngrdanny22 said:Hey Plum, would you be able to make a transmission crossmember like the one in this article (from TRS):
http://therangerstation.com/tech_library/sas.html
I also have the same Radius Arm drop brackets as in the article, but I need a crossmember for the support.
Thanks man!
Ok man, I'll try and get the measurements sometime in the next month or two!PlumCrazy said:I could deff do that, but I would need some pretty precise measurements.
-PlumCrazy
I quoted a guy 300 (+ shipping) for a bumper like mine a while back, so I would say the same for you, but I dont have any 03 Rangers to use as a model.(I may know some one with an 01, but IDK if they are the same.)Red said:i would like to know how much it cost u to build ur front bumper thanks man
