Hey all.
Right now I have for parts/race-truck;
1) 86 ranger ext cab 2wd 2.9 auto -good body -motor toast -rebuilt trans
2) 87 stx ranger reg cab 2.9 auto d-28/7.5 4.10 gears -motor gone
3) 90 reg cab 4.0 standard d-35 8.8 3.73 gears (roll-over) -running o-k
4) 91 reg cab 2.9 stan. d-35 8.8 unknown gears -running o-k,
5) 91 exploder 4.0 stan d-35 8.8 unknown gears -running good -rebuilt trans -(roll-over)
Various other 2wd rangers pre 90
85 b-II play toy + 3 parts b-IIs
My thinking is to keep the center of gravity as low as possible-thus no lift if possible.The stx came with a 2" lift from the factory. The 90 was in a roll-over so the frame may be bent.
So, my thinking,no lift; use the 91,swap in the 4.0 and trans from the exploder, and the 3.73 from the 90.
with lift; use the 87, swap in the 4.0 and trans from the exploder, keep the gears.
Yours thoughts?
Thanks
p.s. starting this weekend, pics to follow.
I thought I would list a running total of my time and money spent, I also posted this info in my first post for those who don't read the whole thread;
Time ~ 204 hrs
Parts;
'90 stx ranger ~ C$200
'87 stx highrider ranger [flat of beer] ~ C$45 C$245
safety related
cage - pro built C$2000 C$2,245
driving suit - new C$345 C$2,590
helmet - new C$145 C$2,735
alum. seats-used (2) C$300 C$3,035
window net - new C$50 C$3,085
fuel cell - new C$200 C$3,285
fuel cell - a/n fittings C$105 C$3,390
fuel cell - low pressure pump C$105 C$3,495
5 point harness - used C$25 C$3,520
master kill switch + elec. misc. C$75 C$3,595
50' 2/0 wire (used jumper cables-homemade) C$25 C$3,620
__________________________________________________ ____
truck related
rebuilt calipers and pads C$90 C$3,710
shocks - 6 pr used - traded for one aluminum seat (C$150) C$3,710
mig wire C$70 C$3,780
shock mounting C$50 C$3,830
grade 8 bolts, etc. C$50 C$3,880
wd-40, zip discs C$35 C$3,915
fan belt C$30 C$3,945
rad flush + fluid C$30 C$3,975
sandblasting frame C$75 C$4,050
tube 1"x1"x10' C$10 C$4,060
brake flex line C$80 C$4,170
brake hose flex line - f-150 C$20 C$4,190
brake fluid, fuel inj. cleaner, misc. C$20 C$4,210
brake hose 60" hard line, hose locks C$15 C$4,225
sway bar bushing kit C$25 C$4,250
oil pressure switch, oil filter, vacuum caps C$20 C$4,270
elec. solder,fuses, misc. elec. C$40 C$4,310
misc. hose and wire clamps C$25 C$4,335
self-etching primer C$90 C$4,425
fuel; line, filters and menders C$45 C$4,470
fire ext., air filter, bulbs C$35 C$4,505
spark plugs, wires, and MORE filters C$105 C$4,610
anti fatigue mat for seat C$15 C$4,625
wire C$5 C$4,630
It looked a whole lot neater [in columns] when I wrote it out before posting.
I'm pretty happy with the way it turned out for under C$5,000
tires; 29/8.50x15" tsl super swampers - mounted and balanced-C$500 C$5130
almost under C$5000
Yours thoughts?
Thanks
Time ~ 204 hrs
Parts;
safety related
truck related
wire C$5 C$4,630
almost under C$5000
