1 - 6 of 6 Posts
The ABS light on my 97 ranger is on, peddle depressed lower than normal and the fluid was low. I added more fluid but it did not help. Could this be a leak or maybe just air in the line?
have someone push on the peddle as you look at each wheel for leaking and put a scanner on it to see what code is showing
Thanks, I forget about scanning . I have a auto zone here and will go to them and see what code comes up.
Thanks again.
It could be an ABS sensor in one of the wheels. I have the same issue in mine right now. You could also check to see if the fuse for your ABS is blown.
1 - 6 of 6 Posts
