i have an 01 3.0 auto and the abs is on. i took it to advance auto and there scanner said left front right front read motor and something else was wrong. it old them they all cant be bad. i took the sensors out and ohmed them and then ran a screw driver past them and saw a voltage change so they appear to be good. so tell me where is the control module for the abs located? advance showed me one on there computer and it looks different than the module on the motor the plugs were different locations. i can't believe all those problems happened all at once. must be either the controller of something else. could a blown fuse cause this? if so where would i look for the fuse i don't have the manual? thanks
