Hey, building a 1998 Ranger with a 545 Big block engine. Engine has SCJ aluminum heads Scat crank and rods with icon pistons designed for the heads also Howards .0700+ lift roller cam and solid lifters . I've spent time as the truck was a 4 cly one. I swapped in a explorer 8.8 and cut the frame plus used Dodge rear springs to make the wheelbase close to 101 inches like a fox mustang. So I have a you tube page and this is it. #https://www.youtube.com/channel/UCwU57qeCk4XQR4Z5jEPAU0Q You can go and have a look. If your on You Tube please sub to my Channel Thank you. I'm in the process of installing the engine. will be using a powerglide Transmission with trans brake system. 4500 Stall converter The rear end has 3.73 gears so I may stick with that and a spool + c-clip eliminators Moser axles. we will see..
