It's a 5 speed manual. We replaced the clutch, pressure plate and bearing. After reassembly it seems the shifter does not put the truck in gear. After bleeding the system the pedal pressure seem as though it does its job.
I can't imagine what is going on other than the shifter being out of sync.
I sure appreciate a voice of experience here.
with the truck shut off and not running can you put it though the gears at all
