Ok i bought this ranger from a guy and he said it has sat for 7 years but the plate on it says 02. i put a new fuel pump, filter and fresh gas in it. Truck will not start it has good pressure at the rail. I sprayed brake klean in the intake because its not as harsh as starting fluid and the truck would start then die. Checked plugs and plugs are good but not wet. What can i be missing that will cause this not to start. I also had to put a new fuel regulator on because it was leaking gas into the vac system.:mad:
