21 - 40 of 76 Posts
Discussion Starter · #21 ·
Re: 1992 F150 Pre-Runner Project
Took more pictures today.
Discussion Starter · #22 ·
Today I pulled off the Chrome off the sides. Is there anyways to remove the sticky stuff off the side? Anyways, I also found the plastic cover that goes over the shifter. Still have the little chrome over the wheel wells. Pictures to come soon.
For the sticky residue, have you tried "Goo Gone"? It seemed to work for me when I removed the stripe off my truck and it left the glue everywhere.
Discussion Starter · #24 ·
I heard that WD40 would work.
I haven't tried WD40. If you use it, be sure to let us know how it works!
Discussion Starter · #26 ·
I've tried some, it was coming off, just a lot of rubbing involved. It didn't leave any residue though.
Discussion Starter · #27 ·
Good to know. Thanks for sharing.
It's coming along man! Good to hear the WD40 is working... probably cheaper than Goo Gone.
Discussion Starter · #30 ·
Yea if you look in this image, half the adhesive is gone. So, just need to work at it, it does though leave it a little greasy, but that's not a big deal.
Also I was pulling off the passenger side bed chrome I found bondo underneath. Also it shows its previous color which was a white, so I got a little work ahead of me, I plan on trying to find a new bed, fix the cancer on the cab, and paint it Black. But heres the picture of the Bondo
Discussion Starter · #31 ·
Good News Everybody!
After many long hours working, I am finally getting close to fixing my truck. In the near future, by the near future I mean next weekend. I found the part I need, and I'm getting what is known up here in AK as a PFD. :D free money. Anyways thought I would update you on this or something. I just wanted to use the Professor.
Discussion Starter · #33 ·
Update
So tomorrow I'm buying a used front axle from a guy. Spark plugs spark plug wires, and a cap and rotor. I have to head to Napa for some exhaust pieces, and get a new windshield, THEN I have to go get the truck to go pass an Emissions test. So I have a busy day tomorrow. BUT!! I will be able to drive the beast after all that is done. (Its been sitting since I snapped a internal part inside my front driver-side axle shaft.)
So here the picture of the axle I'm buying.
Fresh off of craigslist.
Discussion Starter · #34 ·
Updates:
New Windshield
New/Used Exhaust
New Front Pumpkin
and pictures to come I lost my camera.
What gears are you going to run?
Discussion Starter · #36 ·
same as stock. which are 3.54 in front and 3.55 rear. About the only thing I'm going to do for now is get it moving. Later will come the mods.
If you are low on money, and plan on driving on pavement regularly, and have a regular rear [not limited slip], you can make a cheap limited slip by adding a side gear shim. It'll make the rear act like a l.s.d. but also shortens the life. I've done this to a 9" and a front diff - a d-35. The 9" has about 20,000 miles on it with no problems, the d-35 has about 200 miles. Don't do it to the front as it makes steering on corners and side hills a little dicey, especially on snow.
Discussion Starter · #38 ·
Yea I'm going to stick with stock for now. Possible SAS later, boss man got it stuck in my head.
Anyways updates, none. My trucks been sitting, but next weekend I'm going to work on swapping the pumpkin, my dad said that the only reason its binding is that something in the pumpkin is messed up. So, he will help me out with some tools, so I can work on the front end. Fun Times.
Discussion Starter · #39 ·
sorry been lazy about getting pictures, anyways I found out what was really wrong with my truck. I guess when they replaced the axle-shaft, someone didn't install the u-joint correctly. So I'm going to fix that this weekend. The truck drives, and everything just need to get it registered.
Discussion Starter · #40 ·
Update:
Well all that's left to do is put together the exhaust. Up here in Alaska they have emissions test each vehicle has to pass to be able to drive it during winter time. So in order to get it on the road I have to make sure it passes, which means fixing any computer errors, and completing the exhaust. The 4x4 works great though, Goes through the snow like a champ.
21 - 40 of 76 Posts
