1 - 5 of 5 Posts
A few weeks ago I overheard my boss saying he was going to sell one of the company trucks, a 2004 F-150 Lariat 5.4 Triton, to a wrecker for $500.00 to $1,000.00. I spoke up and said I would pay $1,000.00 for the truck. I figured at the least I could part it out for double what I paid. It's pretty loaded; auto, 4 doors with PW, leather PS w/heat, cruise, sun roof, buckets and console, e-4x4, good factory sound, new 18" tires.
When I drove it out to my place, it fired right up with a smooth idle and took off just fine. Wow, I thought, there's nothing wrong with this truck, what a bunch of morons I'm working for!!! After traveling for about ten minutes I came to a stop and the motor was stumbling and almost dying, I had to feather the gas in order to keep it running. I guess the boss isn't such a moron after all. After doing some research I found out the 5.4 is known for the cam phasers buggering up due to lack of oil changes. It seems the oil passages are easy to plug and without regular oil changes the passages plug and the phasers don't do what they should: keep the cams in phase with speed and load. I spent a couple of days online researching and then talked to my local mechanic. He said that if I didn't have bad oil pressure that it is feasible to repair the phasers, cost ~$2,500.00 parts and labor. With bad pressure, the option is replace the motor, either with rebuilt or from a wreck. Cost with motor from wreck; ~$6,000.00 includes parts and labor. A shock to me was the 24 hour time span it takes to r+r the motor, the engineers must have been having crack withdrawals. Anyways, I drained a liter of oil and replaced it with trans fluid. I ran it like that four or five time over the course of a couple of weeks, putting on about 10 kilometers. I then decided to add a manual oil pressure gauge teed off the stock sensor;
I flipped the rubber cup holder upside down, it was the only place I could find to hold the 2 1/2" diameter gauge;
What a pain in the wrist it was to tee off the motor, I wish I had another joint between my wrist and elbow.
After draining the oil, which had a total of about 100 kilometers on the last oil change that the company did, it looked a little dirty. It looked like it had copper pearl added to it, I hope its not worn too much inside. The recommended oil is 5w/20. In my research, it was suggested a quick fix was to go to a heavier oil, so I decided to mix 0w/30 and 15w/40 half and half to make 7.5w/35. It seems to be working!!! Cold idle was 72 psi, warm idle dropped to 60 psi. After running hard for 5 or 10 minutes the in gear idle pressure was 23 psi and in park idle was 30 psi. In gear at 1000 rpm and higher the pressure was @ 55 to 60 psi. The truck seemed to run smooth the whole time, other than a tick similar to a 2.9 or 4.0 lifter tick. Maybe the thicker oil is preventing enough oil from reaching the upper parts of the motor, but I don't have a clue. Can anyone shed some light on this? Anyone with experience with what I'm attempting please speak up.
Thanks,
That was a killer deal on that truck! Worst case scenario, like you said, would be to part it out. You would probably triple your money.
Thanks to everyone on the different forums for the responses. I'm pretty sure that I won't lose on this truck. I figured I'd keep this thread updated with what I find out, at the least it may help someone in the future.
I've gone through the receipts that came with the truck, from 116,000 Km to present @ 215,000 Km. The rear diff was rebuilt @ 180,000 Km 3.73 gears, auburn limited slip. The spark plugs were changed and the fuel system gone thru @ 185,000 Km. Actuators [4x4?] and front bearings @ 202,000 Km. It seems there was regular oil changes ~ 5000 Km. The last receipt is for diagnosis; code p022 - cam position timing over retarded bank 2, may need t/chain, belt, variable cam timing actuators, and chain guide. And garage replaced oil sending unit and bank 2 variable cam timing solenoid at that time.
I pulled the codes [unsure of procedure but wth, I gots to lern sometime lol] and got these the first time;
p0134 o2 sensor circuit no activity detected bank 1 sensor 1..... is this indicating the first o2 isn't working or maybe the wires are dislodged?
p0171 and p0174 system too lean banks 1 and 2.... maybe has something to do with 1st code?
After fiddling with reader I pulled another code;
p0022 a camshaft position timing over-retarded bank 2..... the same as the garage pulled.
I don't have enough experience for diagnosing the problem, I'm a 50 year old playing with cars and maybe learning something along the way. I will buy the manuals needed and if someone is kind enough to give directions, I can and will fix the problem, I don't give up easily. I once pulled the ac from a '91 ranger without letting any gas escape because I was told it couldn't be done, tho it did take me quite some time....and it never got put back in.
After putting in the a fore mentioned 7.5w/35 oil I went for a 100 Km drive and the truck ran great until coming to a stop in gear. Oil pressure was @ 55-60 psi at cruising speed of 110 Km/h, 1800 rpm, not fluctuating except in relation to rpm. At a stop oil was @ 20-23 psi, 500-650 rpm. Rough running was experienced when oil dipped below 23 psi and idle dropped rpm in relation. Feather the gas and idle smoothed out. Turned around and drove back no problems, gas mileage indicator showed an average of 15.2 L/100Km over the whole trip. No codes came up after the trip. There are no problems experienced until an extended driving time.
I'm inclined to do as berry1234 suggested; de-sludge the engine for 1000 Kms and next oil change I'll use 15w/40 as I happen to have some synthetic of that grade I picked up for cheap. When I ran 5w/20 the motor ran like crap warmed up at an idle, I didn't have a oil pressure gauge installed at the time.
OTOH it may be best to tear into the front of the motor and fix the possible blown chain tensioner 'gasket' as suggested by Sasquatch_Ryda. Can anyone give me an estimate of time and parts needed for this?
Thanks,
love that truck hope the drive shaft dont go out ill tell you more about that later on and i would just jump right in to the timing belt and gasket wish you luck
1 - 5 of 5 Posts
