I have a 02 ranger xlt.. problem is that when I press the driver side window switch down it dosent go down.. changed the motor cuz it was shot anyways.. I get a click from the relay also.. the button for the passenger side works on the drivers side switch but the passanger switch dosent work either... what could be the problem.. fuses are good. And preety sure relays are good.. could it be the switch is bad on driver door and also bad switch on passanger door?
